D2 Power-Steering Pump
Old 03-01-2017, 10:07 PM
LR03NJ's Avatar
Originally Posted by dwatterson1
My power steering assist is going out will it hurt anything to drive without the power.
Your arms will. you wont be able to turn once it all went out on you. Try without turning the engine on, then try if you can steer it. It will be same as without the power steering. Better to fix it than driving without.
Gerry
  #22
Old 03-01-2017, 10:42 PM
chubbs878's Avatar
New Nachi 6302 installed to the PS pump output shaft.
Heated shaft @ 350 degrees for 20 or 30 mins while bearing sat in the freezer.
Install of new unit wasn't half the battle that removing the orig unit was...
Placed the assembled unit into the freezer to cool off for a while.
Now I will order the seal kit & update with the reassembly next time.
Attached Thumbnails D2 Power-Steering Pump-img_2345.jpg   D2 Power-Steering Pump-img_2346.jpg   D2 Power-Steering Pump-img_2347.jpg
  #23
Old 03-02-2017, 05:06 AM
Surely the other way around Chubbs, you would need to shrink the shaft in the freezer and allow the bearing to expand in ambient temp or heat up to 40-50C.
  #24
Old 03-02-2017, 05:09 AM
Gerry
X1
Unless you're Herculean or a male gorilla PAS is essential and near impossible to steer without it.
  #25
Old 03-02-2017, 07:13 AM
shanechevelle's Avatar
Shhhhhhhhhh.
Lol...heat that bearing...350
johnnyjohnny
09-26-2019 09:37 PM
joshjellel
02-16-2015 10:53 AM
Sandman0306
12-15-2012 03:24 PM
orionpaxx
11-07-2011 10:07 PM
losinov
03-21-2011 08:57 PM
Quick Reply: D2 Power-Steering Pump
