D2 upgrade information.
Old Feb 17, 2020 | 12:57 PM
Sixpack577's Avatar
Originally Posted by Best4x4
You want TC/HDC disabled unplug a wheel sensor.... aka 3 Amigo’s = no TC or HDC whatsoever.
Could that be done with a toggle switch then?
Still have to reset codes each time?
Old Feb 17, 2020 | 01:02 PM
whowa004's Avatar
sounds like yes you could add a switch inline to any wheel sensor but I'm not sure on the clearing of the codes.
Old Feb 17, 2020 | 02:25 PM
Sixpack577's Avatar
I'm going to do option B after mine runs again(I got 3 amigos one time before I pulled my engine. I engaged the cdl and they went away. I figured the solder joint was going bad).
I will try a switch while I do option B, and before I seal it back up. I assume I'll have to reset codes, but that's easy enough.
As I agreed above, I don't want to gamble turning the truck off to turn off TC either. Murphy's Law says it doesn't start back at the worst possible time.
Old Feb 17, 2020 | 03:57 PM
Bignacio's Avatar
+1 on BEST4X4. A while back before I fixed the 3 Amigos with the Option B, I was out wheeling and the 3 amigos popped on. I remember having NO TC...
Old Feb 17, 2020 | 06:17 PM
mln01's Avatar
Originally Posted by Sixpack577
I'm excited to try turning TC off(once I get my D2 running again).
I actually like spinning tires and a bit of a challenge.
I hope this is tongue-in-cheek.
Originally Posted by tec31
Hi guys, I am after some technical information on my 2003 D2 v8 upgrade, is there an official Land Rover website where I can get info on how exactly the traction control works with and without the center diff lock, and whether there is a way to turn off the traction control when required ...
When would disabling the TC be "required?"
Old Feb 17, 2020 | 06:29 PM
Sixpack577's Avatar
Tongue in cheek, lmao.
No, completely serious.
Drive it like you stole it.
I wish it could be shifted to just real wheel drive so I could drift it. If the surface is slick enough, you can get 4wd sideways, as well as donuts on center...TC messes all that up.
Old Feb 17, 2020 | 07:18 PM
No Doubt's Avatar
Talking
I don't the idea of turning it off either.
When I originally asked about this in another thread, I wanted to know if basically option B could be done with an inline toggle switch. So you could turn off abs, hdc, and tc all by flipping one switch.
Assuming so, if flipping the switch back then turns them all back on, or if codes must be cleared first(I have an Ultragage and a Nanocom).
Neat idea!
Old Feb 17, 2020 | 07:34 PM
Sixpack577's Avatar
Originally Posted by No Doubt
Neat idea!
Thanks...but we'll see if and how well it will work.
Old Feb 17, 2020 | 08:46 PM
Best4x4's Avatar
If you had option B all you’d have to do is unplug it. 3 Amigo heaven as soon as you turn the key.
Vs other vehicles out there the TC on the D2 is really no where near as sensitive. Off road it does it’s job excellent. On the highway I’ve never had it come on say when driving in the rain. My work truck = TC and ABS pulsates constantly the entire drive in the rain for example.
I’ve drifted a D1/D2 a few times & I can tell you right now doing that on a regular basis & you’ll be swapping TC’s out often.
Enad
Mar 26, 2019 12:29 PM
Mr. Tick
Dec 9, 2017 11:07 PM
Second2None
Oct 24, 2010 07:01 PM
catchmyktm
Jun 5, 2008 10:59 AM
JVG1999
Mar 11, 2006 06:34 AM
