D2 wheel bearings
Old Aug 14, 2015 | 11:25 AM
jroztocil's Avatar
Default D2 wheel bearings
Hi
is there any way to bypass original hub with the bearing?
kind regards
jr
Old Aug 14, 2015 | 03:12 PM
Charlie_V's Avatar
Originally Posted by jroztocil
Hi
kind regards
jr
Sorry but what do you mean by bypass?
Old Aug 14, 2015 | 03:51 PM
ZGPhoto's Avatar
That may be one of the funniest first posts I've ever seen.
Bypassing a hub..... interesting...
I'm going to translate the very questionable question and guess you're asking if you can just replace the bearings in the hubs?
Old Aug 14, 2015 | 04:36 PM
drowssap's Avatar
Either way the answer would be not practicle, when you can buy a new hub & ABS senaor for approx. $80 on ebay.
Old Aug 17, 2015 | 02:33 AM
jroztocil's Avatar
Hi, yeah didn't get it quite right, you right I meant to replace bearings only! Thanks for your translation, the reason to try to change bearing only is the prohibitive cost to purchase complete assembly here in South Africa. Granted I can source from abroad but then the shipping and insurance and tax on top of it make the cost price 4x higher than you guys buying it for, Thanks in advance, Jr
Old Aug 17, 2015 | 08:22 AM
Charlie_V's Avatar
4 times?! CRAP! Hopefully you don't have to replace them often. But I am sure you already know it is a sealed unit so the general answer is, no, you can't do that.
I have read somewhere about people replacing bearings in D2 hubs in a shop. I'll see if I can find it.
Can't find it. This is a great write up on the replacement procedure: . Someone on these forums directed me to replacement hubs that are only 80 dollars (new, with sensor, I think) and Paul Grant (also on the forums) reportedly has used ones. Abran probably has used ones, too. I don't know about shipping to SA, though.
Rover Curious
Dec 23, 2011 05:26 PM
NiveK1970
Oct 28, 2009 11:12 AM
bklahl
Oct 12, 2006 04:38 PM
bklahl
Oct 10, 2006 03:11 PM
sanmigmike
Aug 24, 2006 03:37 PM
