Brake light
Old Aug 13, 2015 | 08:53 AM
jamestfl's Avatar
Default Brake light
Lately I've had the brake light coming on intermittently. Seems to go away when I can hit the brakes. Sometimes comes back, sometimes not. Not comfortable hauling wife and baby. Thoughts?
Old Aug 13, 2015 | 09:32 AM
cappedup's Avatar
Your meaning dash light? Which one?
Does it flash or stay solid when it's on?
Can you check for codes yourself? If not take it to a parts store, who will read codes for you.
Need more info.
Old Aug 13, 2015 | 09:43 AM
drowssap's Avatar
you will need some place or someone that can read ABS codes
Old Aug 13, 2015 | 09:59 AM
jamestfl's Avatar
Need more info.
Can check codes, will do. The dash light / hand brake light.
Old Aug 13, 2015 | 02:22 PM
abran's Avatar
Add fluid to your reservoir, its low and the movement of braking etc. is causing the sensor to signal its low.
Old Aug 17, 2015 | 10:26 AM
jamestfl's Avatar
Thanks. Will do.
Old Aug 17, 2015 | 01:18 PM
Joemamma1954's Avatar
This is what stopped mine from coming on intermittently.
Rover Newbie
Jul 13, 2014 10:46 PM
rreinholt
Oct 10, 2013 08:47 AM
Florida04RR
Mar 10, 2010 06:09 AM
bigbris1
Jul 3, 2007 08:02 PM
