Dash cluster lights out
Old Nov 4, 2017 | 02:13 PM
Redleg13fa's Avatar
Originally Posted by Best4x4
the ebrake switch/connection is located on the handle itself. You can see it if you remove the leather boot & the window switch panel.
Thank you for your help, replaced the cap and it went out. Now to trouble shoot my back up sensors, and then o2 sensos
Old Nov 4, 2017 | 02:14 PM
Redleg13fa's Avatar
Thank you for your help, replaced the cap and it went out. Now to trouble shoot my back up sensors, and then o2 sensors
Old Nov 4, 2017 | 02:56 PM
Best4x4's Avatar
Good Deal!
The brain to your backup system is located in the rear cargo area. If you have the rear cargo door open you'll see two vents on either side of the cargo area located nearest the cargo door. On the right you can access the fuel door solenoid. On the Left you can access the Rear AC Blower or if it's got park distance control you'll see the brain mounted back there. I've heard of several people using cheaper Ebay sensors and just wiring them into place vs going with OEM sensors.
Old Nov 4, 2017 | 03:01 PM
Redleg13fa's Avatar
Good Deal!
oh ok sweet. It' funny that when I put in reverse the system beeps momentarily but than quite down. I'e pushed the button on or off multiple times and nothing happens. It doesn' sense Jack. But I will definitely look there. Thank you
Old Nov 4, 2017 | 04:22 PM
mln01's Avatar
Don’t the cluster and ECM need to be swapped together otherwise the odometer will flash continuously?
Old Nov 4, 2017 | 07:43 PM
Best4x4's Avatar
You can cheat if you have issues with a gauge. I even was able to put an 03-04 looking gauge cluster into an 01 without having to do anything. If you have issues with a gauge just remove the small silver screws that attach the gauges to the PCB. Then swap over the new gauge or the 03-04 looking gauges onto your PCB with the correct mileage BOOM new gauge or new look without needing anything else.
""""On a side note I have been able to successfully swap 99-02 gauges onto 03-04 PCB clusters with zero issues. However when doing some 03-04 gauges onto 99-02 PCB clusters I have had a 50/50 success rate. You'll know it's wrong when both outer gauges (Temp & Fuel) read backwards. I've swapped some that worked flawless and I've attempted to swap some that didn't. I think it's a firmware issue with the later PCB vs earlier ones.""""
If you swap out the entire unit it will have to be re-synced. Unplugging the gauge cluster, and even just pushing the D2 with the key on = will no longer be synced.
tomfraser
Apr 22, 2023 07:30 AM
lr2001silver
Jul 16, 2012 02:27 AM
ashhun2412
Jul 4, 2012 02:42 PM
Doral300sc
Feb 6, 2010 03:59 PM
tonyzp007
Jan 26, 2007 11:21 PM
