Dash Light Out
Old Oct 3, 2011 | 08:31 PM
marshman442's Avatar
Default Dash Light Out
The center section of my DII dash is dark. Is there a bulb in the center (where the tach and speedo come together) or is this an LED type display? Is there a way to replace this bulb?
Old Oct 3, 2011 | 09:59 PM
RAVE wiring diagram shows it to be a bulb.
The wiring send battery volts thru the variable dimmer switch to a splice that serves a number of lights. One other light is the cruise control button.
Old Oct 3, 2011 | 10:42 PM
Next question is how to replace this bulb, and my guess is this is a dealer only part....correct?
Old Oct 4, 2011 | 07:02 AM
I got some bulbs at NAPA, like for the clock. Better on line than from dealer, but problem will be that your dash clusterwill be out to deal with this, and will need it fixed quick. See Land Rover Discovery II Electrical Switches and Relay Parts Available from RoversNorth.com, looks like item 32. Don't know if you can reach under there and twist it to come out.
primey
Oct 5, 2011 10:06 PM
novavon
Oct 23, 2010 02:36 PM
rphotographer
Oct 28, 2008 12:29 PM
firebell
Mar 29, 2008 06:24 PM
alpinab7
Jul 23, 2007 09:02 PM
