dash lights
The latter three lights are "The Three Amigos." If the brake light is truly on, that indicates a serious problem. The (red) brake light will cause the Three Amigos to appear. The most common cause of the brake light would be low brake fluid.
Low brake fluid could indicate pad wear, or a leak, among other things.
If the red brake light is on, the vehicle should not be driven until diagnosed and repaired!
