Dash lights out and selector out
I know this is a old issue but I’m STRESSED OUT. All fuses are good headlights, taillights , signals , hazard, all working.All I did was change the bulb in the glove box after that dash lights and selector switch not working. I don’t think it’s the cluster bc the warning lights still work.
Any Clues Discos?
Any Clues Discos?
Did you short out the glove box light against the metal when re-installing it? Check your fuses, I bet you popped one as the Glove box light only works with the lights on. It does not work any other time, so if you have the lights on to test it, and shorted it against the metal POP goes a fuse.
