Dash lights out and selector out
Old Sep 11, 2020 | 08:11 PM
Silverredx7's Avatar
Default Dash lights out and selector out
I know this is a old issue but I’m STRESSED OUT. All fuses are good headlights, taillights , signals , hazard, all working.All I did was change the bulb in the glove box after that dash lights and selector switch not working. I don’t think it’s the cluster bc the warning lights still work.
Any Clues Discos?
Old Sep 11, 2020 | 09:08 PM
Best4x4's Avatar
Did you short out the glove box light against the metal when re-installing it? Check your fuses, I bet you popped one as the Glove box light only works with the lights on. It does not work any other time, so if you have the lights on to test it, and shorted it against the metal POP goes a fuse.
Old Sep 11, 2020 | 11:25 PM
That is exactly what I did but in can’t find the fuse unless there’s one under the steering column
Old Sep 12, 2020 | 11:05 AM
Thanks for the info all gd now fuse #3 I also
put electric tape on the connector of the glove box
light just in case I do it again
The Bus is back on the road
Old Sep 18, 2020 | 11:15 PM
Default Rear cargo speakers
Is there any speakers that’s close to a direct for the rear cargo subwoofers .My subwoofer are shot previous owner had leaks from the tailgate. Was thinking of replacing them with 6.5 waterproof speakers just in case but can’t find a compatible pair
The Bus
Old Sep 19, 2020 | 08:51 AM
Best4x4's Avatar
Pyle Subs
Jordan Branstetter
Dec 24, 2018 10:00 PM
Rufflyer
Nov 5, 2018 10:33 AM
lr3_ovrlnd3r
Apr 9, 2016 08:24 PM
samgru
Dec 15, 2008 12:47 PM
LiftedRover96
Feb 7, 2006 10:24 PM
