Dash removal
Old Oct 27, 2012 | 09:32 PM
bigcraigman's Avatar
Default Dash removal
So the one thing that makes me mad is when people decide to cover up problems with these trucks instead of just fixing it!!! It f**king lazy. Anyways.... I am pretty sure my traction control lights and ABS lights are on but it appears previous owner took the dash off and took the bulbs out. I tested the HDC and it seemed to work but hills in pensacola are not very big. I just wanted some advice on what to be careful with removing the dash to fix whatever the PO did whether it be removing the bulbs etc. I know if I disconnect something the miles will blink showing that it was disconnected for a while which would scare anyone that might buy it. I have no intentions of ever selling it but you never know. Any advice would be helpful. I just want to verify the problems so I can tackle the amigos. Thanks
Old Oct 27, 2012 | 10:12 PM
lr2001silver's Avatar
Banned
You should be able to disconnect battery and begin your search. Just make sure that you do not unplug your gauge cluster with battery still hooked up its a rare event that your odometer will suffer the flashing symptoms but if it does you would will just end up having to find a reputable shop with the correct computer to reprogram your odometer back to your bcu it can be done I just went threw this ordeal.
Old Oct 28, 2012 | 09:45 AM
The DII uses LED's not light bulbs, they are soldered into the circuit board.
I'm sure they can be replaced if a guy could solder and had a Radio Shack near by to get new LED's.
Old Oct 28, 2012 | 04:01 PM
Yeah I talked to lrsilver about this and the PO smashed the LED behind TC and ABS. Didnt think about soldering the led's back in though. I will have to talk with a friend about this to see if he can do it. I have only soldered a couple things in my time. Thanks for the tip.
Old Oct 28, 2012 | 04:50 PM
Let us know if you can do it or not, it is up in the air on if it can be done or not.
Old Oct 28, 2012 | 06:12 PM
bballjames's Avatar
I am also very curious to see what happens here. I have the exact same issue in my truck. All the LEDs behind the three amigos are not smashed but completely gone. I would like to get them working again without replacing the cluster.
ljdiscovery
Oct 17, 2015 08:43 AM
LolisDisco
May 11, 2014 11:19 PM
courtslu
Jan 14, 2009 05:44 PM
ECL
May 7, 2007 01:06 PM
duoglide98
Mar 7, 2005 08:26 PM
