Dash on the rise..
Old Aug 16, 2018 | 06:14 PM
jerichards93's Avatar
Question Dash on the rise..
Anyone fixed this dash issue? I haven't seen any threads on it. If so do you mind sharing your experience? What should I do/not do. Glue used? etc.. I want a strong fix but I don't want to see any sticky/dried up glue.
Any input would be helpful!
Thanks!
Old Aug 16, 2018 | 08:53 PM
Best4x4's Avatar
Go to Atlantic British website search for D1 dash kit. It’s like 54.00 for the britpart version of the LR dash kit (D1 & D2 dashes are nearly identical). Get the black one, and install it. Then sit back and never worry about it peeling up ever again from the front! I’ve installed several into a few customer D2’s now and even my 04 D2 (pics of the dash kit are in the build thread forum).
I swapped the crappy screws out for the same length sheet rock screws & not only do they look better, but they were MUCH easier to screw into the hard plastic below the soft dash upper.
Old Aug 16, 2018 | 09:01 PM
Llamasayswhat's Avatar
Best4x4 - when you did your install, what did you use to drive them in? low profile right angle air ratchet?
Old Aug 16, 2018 | 09:09 PM
Best4x4's Avatar
I used a small little 1/4 ratchet/ bit driver kit. It was 10.00 at wally world and it’s come in handy more than once so far with trim & very tight spaces.
Old Aug 16, 2018 | 11:35 PM
99FLDISCOII's Avatar
Banned
What year how many miles /kms on your truck?
Old Aug 17, 2018 | 07:58 AM
Best4x4's Avatar
Year & miles have nothing to do with the dash curling. 94-04 D/D2 will all do it eventually. If it starts to curl just get the kit & call it a day.
matt3502
Apr 28, 2020 02:55 PM
Aj6543
May 7, 2018 04:17 PM
09dewaed
Dec 28, 2017 10:20 PM
lrjon
Feb 7, 2013 10:16 AM
nick1996rover
Feb 12, 2005 12:46 AM
