Data link on a 1994 3.9L Discovery I
Old May 21, 2010 | 09:47 PM
ainiguez's Avatar
Default Data link on a 1994 3.9L Discovery I
Can anyone please tell me where the data link connector is on a 1994 Discovery I?
All Data website said on the right hand side below glove compartment, but it doesn't seem to be there.
I know it is not an OBD II, it is one with 5 pins, again, according to All Data.
Thanks
Old May 21, 2010 | 10:00 PM
greg409's Avatar
Thanks
If I'm not mistaken, didn't they have it under the pass seat?
It had an led, I thought, that would give you the codes.
luck,greg
Old May 21, 2010 | 11:41 PM
ainiguez's Avatar
There is a code display unit under the passenger seat. But I have a SRS light that blinks for some minutes then stays steady on. In addition, the antilock light is also on and I wanted to see if I could get the mechanic to turn them off. The display shows nothing.
There is a red plug next to the display under the seat but it seems to have the shape as to accept a relay. There is a black one like this under the glove compartment as well.
Old Jul 10, 2022 | 10:39 PM
Mapo007's Avatar
3rd Gear
Hola, yo tambien tengo un problema parecido. Me señala codigo 12 el visor, pero no tengo los codigos OBD1 para saber que falla es. Mi land rover es del mismo año 3.9 V8
Old Jul 11, 2022 | 12:52 AM
JohnZo's Avatar
I have a 3.9 also. I did a search online and found code 12 is for the Mass Air Flow sensor (MAF). There might be more codes besides that one, the display only shows one at a time.
Old Jul 11, 2022 | 02:58 PM
Best4x4's Avatar
On a 94-95 D1 you'll have airbag faults usually with a bad clockspring or an SRS sensor or wiring.
Old Jul 12, 2022 | 09:59 AM
WaltNYC's Avatar
Put the ignition switch in position II.
Disconnect the Data Link Connector (DLC) , which is located behind R/H side of dash, and wait 5 seconds. Reconnect data link connector.
Put the ignition switch in position 0 and wait till the load relay drops out.
Put the ignition switch in position II. The display will be blank if no other faults exist. If other codes exist, the next fault code will be displayed.
If multiple faults exist, repeat steps 1 through 4 until all faults are cleared. NOTE : Code 02 indicates that the Engine Control Module (ECM) has just been reconnected. Switch the ignition switch to position II to clear code 02.
Code
Circuit Or Condition
02
Battery Recently Disconnected
03
ECM Memory Recently Cleared
MAF Sensor
14
ECT Sensor
15
Engine Fuel Temperature Sensor
17
Throttle Position Sensor
18
Throttle Position Sensor/Mass Air Flow Sensor
19
21
Fuel Tune Select Resistor
23
Fuel Supply
25
Ignition Misfire
28
Air Leak
29
ECM Memory Check
34
Injector Bank A
36
Injector Bank B
40
Misfire Left Bank
44
HO2S Left Bank
45
HO2S Right Bank
48
Idle Air Control Valve
50
Misfire Right Bank
59
Group Faults 23/28
68
Vehicle Speed Sensor
69
Park/Neutral Position Switch
Philip Chan
May 11, 2019 10:44 PM
lr3_ovrlnd3r
Apr 10, 2016 09:12 PM
Pbpuckett
LR2
Feb 5, 2014 09:07 PM
Bob Loblaw
Apr 26, 2013 12:42 PM
wheelgarage
Jun 19, 2011 08:23 PM
