day time runing lights
The BCU can be configured for DRL as follows:
None: The vehicle is not fitted with daylight running lamps.
No main: The daylight running lamps are on if the headlamp main beams are off.
No heads: The daylight running lights are on with headlamp main and dipped
beams off and the gearbox not in Park.
I would think the No heads would do what you want, it would turn off the DRL in park, I think. I'm not sure if that's how Canada wanted them to work or not, but it would probably only be an issue if you have to get regular inspections.
Daddybigdaddy
01-25-2014 10:19 AM
