day time runing lights
Old Aug 26, 2011 | 08:14 PM
redwhitekat's Avatar
Default day time runing lights
hey folks i know on most cars u just pull the emer brake and the day time lights go off, not the case with the 2004 d2, does anyone know how to briefly shut them off, i go to the movie drive ins and just wondering if theres a trick to shut them off
Old Aug 26, 2011 | 08:59 PM
Do these lights come on when car is started, or do you have to turn head light switch to position 1?
Old Aug 26, 2011 | 10:26 PM
lordmorpheus's Avatar
IIRC from RAVE, it's a programming option in the BCM.
Old Aug 26, 2011 | 11:25 PM
jafir's Avatar
The BCU can be configured for DRL as follows:
None: The vehicle is not fitted with daylight running lamps.
No main: The daylight running lamps are on if the headlamp main beams are off.
No heads: The daylight running lights are on with headlamp main and dipped
beams off and the gearbox not in Park.
I would think the No heads would do what you want, it would turn off the DRL in park, I think. I'm not sure if that's how Canada wanted them to work or not, but it would probably only be an issue if you have to get regular inspections.
Daddybigdaddy
Jan 25, 2014 10:19 AM
johno 2925
Jul 30, 2013 04:25 PM
123mct
May 17, 2013 09:06 AM
seniordon
Jan 17, 2011 12:26 PM
wesley64
Sep 12, 2008 11:39 AM
