Follow up... I fitted the required XBL100200 DRL resistor ($15 eBay) inside the LH headlight area of my 2001 Disco 2, removed the unneeded jumper wire and connected the resistor, and then reprogrammed the BCU for DRL with my Nanocom.
I now have DRL on the front headlights with no rear brake light illumination.
-- 03 & 04 have a different system/ wiring circuits for DRL's (and different headlamps). They can just be activated without adding equipment
-- 00 to 02 you must add in the resistor module (big silver box about 4-5" wide), remove the jumper wire to plug it in behind drivers headlight, as the poster above did, then enable with Nanocom.
-- 99's in US market came with the resistor and just require the Nanocom or similar to activate.
