Dead pedal delete?
Old Oct 28, 2011 | 05:51 AM
RenoHuskerDu's Avatar
Default Dead pedal delete?
Hello fellow Discites,
I'm a pretty big guy, 6'6" in the morning, and my left foot needs more room. I'm eyeing that dead pedal on the lower driver kick panel. Is there something behind like an electronic module it that requires protection, or can I just remove it?
On my Disco, it's molded right into the kick panel. But a little sheet of aluminum or SS and a few rivets could cover the hole left after I cut it off.
Anybody BTDT?
Old Oct 28, 2011 | 06:54 AM
drowssap's Avatar
I don’t know about the dead pedal but there is a way to move the seat on its mounts so that it will go back further. But you lose rear leg room obviously.
Old Oct 29, 2011 | 02:13 AM
I did a simple seat mod, same as I did on my RR, by raising the front seat mounts about an inch. This inclines the seat cushion just enough to give me more thigh support. The RR was a bit easier as it only uses spacers under all four mounts, but the Disco was not too hard either. Those pesky reverse-allen bolts are a pita.
FAST5
LR2
May 28, 2014 03:52 PM
disco118
Dec 23, 2011 07:39 AM
coors
Apr 17, 2011 02:29 PM
DiscoIsNotDead
Feb 19, 2011 11:01 AM
SmyLeOrElse
Jan 10, 2007 02:38 PM
