decarb my engine! and oil question
Old 11-12-2007 | 08:23 PM
Default RE: decarb my engine! and oil question
Make sure you use the full can of SeaFoam, run supreme, clean your t/body and put the 44K in when you can get out on the road and drive for at least two hours to get the best results.
Old 11-13-2007 | 08:45 AM
hobiecat's Avatar
You have received plenty of solid recommendations in this thread. However, DO NOT USE JIFFY LUBE. They are franchised and you do not know if the owner is using lower grade oils. Also, always use a good brand for your filters. Cheap filters are just that, CHEAP. They will not do what you are looking to do if you want to keep the truck for 200K +.
Rufflyer
03-22-2015 10:13 AM
Beaulim
05-02-2014 08:03 PM
Paul3221
11-25-2013 12:12 PM
humroot
07-03-2010 10:29 PM
shagybruce
02-08-2007 02:52 PM
Quick Reply: decarb my engine! and oil question
