Dented Back Door (Advice Request)
Old Dec 11, 2014 | 11:50 AM
Jean Filion's Avatar
Default Dented Back Door (Advice Request)
I have a problem with a large dent in my trunk door.
Someone must have backed my Land Rover Discovery 2 into something with quite a lot of force.
Any advice on how to get this out? I've already tried pulling hard on the spare tire mount.
Is there a way to dis-assemble the inside of that door so I can hammer it out?
Old Dec 11, 2014 | 12:03 PM
dusty1's Avatar
yes you can pop that panel off. remove storage tray and speaker 1st
Old Dec 11, 2014 | 01:08 PM
That's great news, I'm going to try that soon.
It looks like the previous owner tried once and busted a number of rivets on the left hand side of that side panel.
Any advice for me before I proceed other than your original ones ?
Old Dec 11, 2014 | 01:15 PM
dusty1's Avatar
You can Get a panel removal tool. I have a couple of sets from harbor freight . The were like $4-$5 a set. Local parts store has them, too. You can always get replacement fasteners if needed. But after speaker and handle screws are out I don't think you'll need much else. I remember it being pretty easy to remove after that
Old Dec 11, 2014 | 11:48 PM
abran's Avatar
buy a new backdoor, depending on where you are, one of us can supply you one for relatively cheap. Location?
Old Dec 12, 2014 | 08:43 AM
dusty1's Avatar
canuckian
Old Dec 12, 2014 | 05:14 PM
sdhow's Avatar
Default On a similar topic...
Is there a way to adjust the fit of the rear door? I have a leak at the top left side; it drips down on to the cargo cover and puddles there.
Old Dec 12, 2014 | 05:17 PM
dusty1's Avatar
not sure that you can tweak enough adjust from the latch and/or hinges. maybe. I would get new weather-stripping first....it tends to break down over the years
Old Dec 12, 2014 | 07:02 PM
Default Total mission failure.
This is my first automotive body repair failure. lol. Even my roof racks are home made.
I took apart the panel, thank you for the advice. I bought a panel popper tool, worked beautifully.
The problem is that on the inside of the door there are very few access holes to the exterior panel.
I started by hammering what I could with a rubber mallet. It didn't budge.
Then I grabbed a socket set and hammered that. What it did was bend the sheet metal into little nipples. The metal bent so much that it cracked the paint.
I really messed up this time. What do back doors go for if I'm looking at buying a used one to replace it ?
Jean
Here are some pics:
Old Dec 12, 2014 | 07:15 PM
dusty1's Avatar
shipping is going to b the deal dud. a few good dismantlers on here can quote you. I just had the entire driver side (2 complete doors and 2 panels) shipped to my place for 6something shipped. you could go to a wrecker yard. I think d1 and d2 have same rear door.
