detroit locker
Old Jun 5, 2010 | 01:57 PM
05gixxer's Avatar
Default detroit locker
Can you run a detroit locker in the rear and keep the traction control in the front .
Old Jun 5, 2010 | 04:53 PM
Sure, the ETC will not have to work as hard. Make sure if you install a Detroit that you install H.D. axles are you'll break your factory shafts.
By the way, I run a rear Detroit and a front T.T. and that basically shuts the ETC completely, and crawls like a mountain goat.
Old Jul 19, 2017 | 07:15 PM
dcaven's Avatar
Which heavy duty half shafts do you recommend for a detroit rear setup in a Discovery II?
Thanks.
Old Jul 20, 2017 | 01:01 AM
Alex_M's Avatar
Mike isn't really around any more. I would say run the stock axles till you break one, then upgrade. I think the strength of the factory axles is underrated. Shade Tree has a Chevy 5.3 in his and runs a Detroit with 4.11s on stock axles. He tells me he isn't afraid of the skinny pedal, either.
Old Jul 20, 2017 | 04:29 AM
yubert's Avatar
I don't think it's necessary to upgrade the D2 axles because the rear axles are stronger than the D1, RRC stock axles. I understand LR made them stronger because they were concerned ETC would add additional stress. I have pictures showing the difference is diameter between the D2 and D1 but can't find it.
Also, the new Detroits don't shock load as hard as the older ones, when they engage. With that said, I upgraded my front and rear axles with Ashcroft axles because money grows on trees.
Old Jul 20, 2017 | 08:18 AM
dcaven's Avatar
Yubert: I have quickly noticed how expensive the Ashcroft stuff is. Has me scared straight. I'm upgrading to a CDL and want to add a Detroit rear and Truetrac front at the same time but the axle upgrade parts are about $700. Yikes!
Old Jul 20, 2017 | 05:10 PM
Mskembo's Avatar
Call up Great Basin Rovers in Salt Lake Utah. They can hook you up.
WARWAGON
Jun 11, 2012 11:00 PM
Jake1996D1
Sep 23, 2011 02:18 PM
dinandan
Jun 12, 2007 05:36 PM
blackdisco2001
Jan 30, 2007 12:45 AM
dinandan
Jun 6, 2006 09:26 AM
