DI Center Console Disassembly
Old Sep 20, 2009 | 03:53 PM
98roverguy's Avatar
Default DI Center Console Disassembly
I never found anything on this forum for the D1 console removal so here's some pics of it. You can break the cover if your not careful.
It is fairly self explanatory after looking at the pics but here's a summary:
1. Remove the "quadrant finisher" (outer black plate) by gently pulling upward. Note the clip locations in the pic.
2. Pry up CDL shift cover in the same fashion then unscrew the ****. Don't lose the rubber o-ring.
3. Remove the two screws under the CDL Cover.
4. Pull up the flat center console piece by moving it forward but do not try to remove. The switch plates is bolted to the back of this. Note the 4 nut locations. Disconnect all window and heater switches. Now remove center console plate.
This is as far as I needed for my project. Perhaps someone who needs to remove more will post pics and continue.
Attached Thumbnails DI Center Console Disassembly-img_0839.jpg   DI Center Console Disassembly-img_0840.jpg   DI Center Console Disassembly-img_0838.jpg   DI Center Console Disassembly-img_0844.jpg   DI Center Console Disassembly-img_0845.jpg
Old Sep 20, 2009 | 04:55 PM
LANDZUII's Avatar
Your setup is different than mine.
I have no wood parts to mess with.
Old Sep 20, 2009 | 05:18 PM
98roverguy's Avatar
Ya the switch panel is bolted to the wood trim on this type of trim level I guess (LSE).
Old Sep 20, 2009 | 05:58 PM
MarvelVT's Avatar
I have the wood trim but I've never seen it in one piece like that. I have a separate piece for the lower part and the window switches. Does anyone know if this is also related to LSE models?
Fail me...I just realized that I DON'T have the wood down on the bottom, just on the window switches and shift ****. However, is single piece still related to being LSE?
Old Sep 20, 2009 | 07:50 PM
My SE has the wood around the switches but not around the shift ****.
Old Dec 5, 2013 | 04:43 AM
antichrist's Avatar
Might want to PM a mod and ask them to move the thread to the D1 section.
BrandonS
Oct 25, 2023 04:41 PM
cybercop
Dec 31, 2014 12:33 AM
johndavidrichards
Jun 3, 2011 09:58 PM
Rearden Steel
May 21, 2011 08:51 PM
kenk
Dec 19, 2009 04:13 PM
