DI to DII axle swap
Old 01-19-2009, 08:53 PM
NiteTrain's Avatar
Default DI to DII axle swap
has anybody swapped an axle from a DI into a DII? If so what kind of problems did you run into?
Old 01-19-2009, 08:55 PM
sloppyjoe's Avatar
Default RE: DI to DII axle swap
why would you do that?
Old 01-19-2009, 09:11 PM
Why?
Wont work.
The DII is wider.
NiteTrain's Avatar
my rear wheel seals appear to be developing a leak...$800 for hubs is not an option
you can narrow any axle
Old 01-19-2009, 09:19 PM
http://www.roverlandparts.com/1999-2...abssensor.aspx
80% of the time a leaking hub on a DII is a bad seal not the hub.
Old 01-19-2009, 09:23 PM
ORIGINAL: NiteTrain
You have a DII right? It is wider than a DI, not the other way around.
So how would you widen the axle? Not to mention that DI's have a full floating rear axle while DII's do not.
Old 01-19-2009, 09:27 PM
NiteTrain's Avatar
ORIGINAL: Spike555
the seal is in the hub..its a unit bearing/hub assembly ..I replaced the O-ring gasket today it's only $1 and Im draining the diff fluid right now..its has something else in with it..diff fluid is milky..Im gussing water.
Old 01-19-2009, 09:31 PM
If the oil is milky then yes you have water in there. Could be from a clogged axle breather or a bad seal somewhere, pinion or hub seal.
Change the diff fluid and then remove your axle breather and make sure that it is not clogged.
My rear axle breather was clogged when I bought my truck, the diff would build pressure and cause a leak at the pinion seal.
Replaced the axle breather and all is good.
Old 01-19-2009, 09:32 PM
NiteTrain's Avatar
you can make an axle wider with wheel spacers..not sure if anybody makes them for rovers..but the D1 axle is just one option...for $800 I could but a ford 9" / dana 44 combo...the coil buckets and perches and the lincoln 135 amp welder Ive been wanting
those hubs at rover land are used arent they? with my luck I would be in the same situation 2 months from now..but $400 poorer
Old 01-19-2009, 09:36 PM
Yes they are used, but also warrentied.
http://www.roverlandparts.com/1997-1...mbly-rear.aspx
http://www.roverlandparts.com/1999-2...mbly-rear.aspx
I just do not think that buying a used axle, and Jerry rigging it to fit will save you any money.
Dont forget that the DII and DI use a different ABS system, so your 3 amigos will be on all the time.
Quick Reply: DI to DII axle swap
