DI wiper arm on DII Problem
Old Jan 2, 2013 | 12:52 PM
0304Disco's Avatar
Default DI wiper arm on DII Problem
Happy New Year Everyone!!
On my 04' I have the DI wiper arm conversion with the bosch Icon blades and they don't clean the windshield exactly at eye level. I had slightly bent the arm when I installed as I believe I had read to do somewhere here.
Any suggestions???
Old Jan 2, 2013 | 01:00 PM
TrailRunner's Avatar
What do you mean at eye level? What size blades do you have on it? I put two different sized blades and found that this worked best for me - I think 19" and 20", but am not sure. I can measure if you'd like.
Old Jan 2, 2013 | 01:10 PM
jafir's Avatar
I've had bad luck with "modern" style wiper blades not wiping the window near the middle of the blade. I put them on my TL(which uses some huge blade like a 26" or something) and I replaced them with cheap old fashion blades.
Old Jan 2, 2013 | 02:09 PM
Try adjusting the tension of the arms against the window. I had to loosen mine a little, surprisingly, to get the best results.
Old Jan 2, 2013 | 02:16 PM
0304Disco's Avatar
Yeah it could be these new high tech blades without the springs that the old blades use. The icon doesn't have a spring rather uses the curve design of the blade to hold it to the window. I'll go back and try the old school ones.
DiscoFever88
Jan 10, 2015 04:03 PM
Snowdog
Nov 16, 2013 11:10 AM
Disco Mike
May 4, 2011 07:08 PM
Roveroh
Feb 21, 2008 03:04 PM
jdelp
Feb 20, 2008 10:11 AM
