Disco 1 wiper arm conversion problem
Old Jan 9, 2015 | 06:18 PM
DiscoFever88's Avatar
Default Disco 1 wiper arm conversion problem
I recently installed the disco 1 wiper arm kit from roverparts.com. everything went on smooth and without problem. Today I purchased bosch icon blades to replace the ones that came with the kit because from the beginning they were streaky and had bad contact. Now with the bosch blades there is still not much contact with the windshield. It is not as streaky but there are large areas on both blades where it does not wipe. I tried reinstalling the arms but no change. any ideas?
Old Jan 9, 2015 | 09:04 PM
acg's Avatar
acg
I have had the same issue with the Bosch Icons blades. The design of the Icons does not provide consistent pressure through the entire length of the blade. I ended up using the generic (and relatively cheaper) wiper blades with multiple spring contacts for more consistent pressure across the length of the blade.
Old Jan 10, 2015 | 09:01 AM
DustyLBottoms's Avatar
Older wiper arms can sometimes have pressure issues, consider that that only thing providing tension is the arm spring. I've found that you can swing the arm open, as if to install a new blade, and then bend the arm LIGHTLY in your hands in order to tighten that spring up.
Old Jan 10, 2015 | 01:59 PM
jafir's Avatar
He said he bought arms from roverparts.com, so I'm assuming they are new.
Old Jan 10, 2015 | 02:11 PM
Hellojello74's Avatar
So I recently did same thing. Tried 21, 20,18" blades in icon and evolution . Each had a spot almost directly under attachment that didn't contact. They were size of hand to football sized. It wasn't always both wipers but at least one. They wiped well everywhere else great. Tried calling Bosch tech didn't get much help ended up with a standard frame wiper blade that works. I was on vacation so got the cheaply ones since I wouldn't be able to return them once I left. Once these ones go I'll try again because they are nice blades. Have heard of others using them on hear and have them on the other car do not sure what gives.
Good luck.
Old Jan 10, 2015 | 02:12 PM
BTW mine were spanking new arms too. First blades installed.
Old Jan 10, 2015 | 02:29 PM
OffroadFrance's Avatar
Do these new fangled wipers like the Bosch Icons do a better job? I've been thinking about changing all of my wiper blades. Problem in France is during the summer where the blades suffer from 'heat stroke' and the rubber persishes even with the LR OEM's so often it's not worth spending too much on wiper blades. For getting sufficient pressure I fit blade spoilers which helps a lot. Normally they only come new with a spoiler on the driver's side blade but I keep the old spoilers for the passenger side. I recycle the old blades onto the Pajero as it sees more muck and grit regularly.
You can buy new springs for the wiper arms (Trico, I think) which are good but a PITA to fit. TIP: wear leather gloves when fitting them 'cos they bite ya
Old Jan 10, 2015 | 02:45 PM
http://www.summitracing.com/int/part...7-26/overview/
There are other springs available in the US on Ebay.
Old Jan 10, 2015 | 02:53 PM
dusty1's Avatar
I like the performance of the rain x ones better.
Old Jan 10, 2015 | 04:03 PM
yea they are both new arms and blades. i am going to bring them back and see if standard blades work better. Ill let you guys know how it goes
0304Disco
Jan 2, 2013 02:16 PM
imike1007
Jul 27, 2012 07:39 PM
Disco Mike
May 4, 2011 07:08 PM
shonuff93
Aug 1, 2009 05:43 PM
jdelp
Feb 20, 2008 10:11 AM
