Diagnosing rebuilt engine - burning oil, lean, and low power up inclines
Old 05-07-2018, 11:50 AM
abran's Avatar
The reading I posted was actually high. That is what I was using as a max value for our intake tube project.
Attached is the at idle value. I revved the motor and the highest value I got was 21in.Hg vac. It shouldn’t make a difference, but this is on a 4.0.
  #52
Old 05-07-2018, 11:56 AM
Jeff Blake's Avatar
Thanks abran. Stock cam I assume?
Sounds like my vacuums are actually normal, assuming yours is running well
I still need to test the exhaust backpressure @ the o2 ports, but the vacuum test indicated no blockage there. oil burning issue aside, I'm pretty sure my uphill performance problem is a combination of heavy weight, 32" tires, and stock gearing.
  #53
Old 05-07-2018, 01:46 PM
abran's Avatar
Stock cam, runs well.
StillRoven
Freelander
06-29-2015 06:08 PM
StillRoven
05-04-2014 11:33 AM
Captian Adrianus
07-09-2012 01:45 AM
tacker
07-10-2010 09:36 PM
bangkuaidiscovery04
02-07-2010 09:31 AM
Quick Reply: Diagnosing rebuilt engine - burning oil, lean, and low power up inclines
