Diagnosing rebuilt engine - burning oil, lean, and low power up inclines
Old May 7, 2018 | 11:50 AM
  #51
abran's Avatar
The reading I posted was actually high. That is what I was using as a max value for our intake tube project.
Attached is the at idle value. I revved the motor and the highest value I got was 21in.Hg vac. It shouldn’t make a difference, but this is on a 4.0.
Old May 7, 2018 | 11:56 AM
  #52
Jeff Blake's Avatar
Thanks abran. Stock cam I assume?
Sounds like my vacuums are actually normal, assuming yours is running well
I still need to test the exhaust backpressure @ the o2 ports, but the vacuum test indicated no blockage there. oil burning issue aside, I'm pretty sure my uphill performance problem is a combination of heavy weight, 32" tires, and stock gearing.
Old May 7, 2018 | 01:46 PM
  #53
abran's Avatar
Stock cam, runs well.
StillRoven
Mar 6, 2025 09:37 PM
StillRoven
Freelander
Jun 29, 2015 06:08 PM
Captian Adrianus
Jul 9, 2012 01:45 AM
tacker
Jul 10, 2010 09:36 PM
bangkuaidiscovery04
Feb 7, 2010 09:31 AM
