Diagnostic Troubles (Requesting Advice)
Old Dec 19, 2014 | 05:08 PM
Jean Filion's Avatar
Default Diagnostic Troubles (Requesting Advice)
Hey Folks,
My Land Rover Discovery 2 SE7 has low engine power (poor acceleration) and lots of smoke coming out of the exhaust.
I had my Bank 2 Sensor I (O2) sensor replaced (it was tripping a fault and SES light) and now I'm getting the Service Engine Soon light again with the following codes:
P1174 Cam Sensor Fault
P1171 Oxygen Sensor System Too Lean Fault Banks A & B
Attached are more info from my diagnostic test while driving (BlueTooth is awesome). Any ideas?
Diagnostic Troubles (Requesting Advice)-screen-shot-2014-12-19-5.10.17-pm.png
Diagnostic Troubles (Requesting Advice)-screen-shot-2014-12-19-5.13.22-pm.png
Diagnostic Troubles (Requesting Advice)-screen-shot-2014-12-19-5.11.33-pm.png
Diagnostic Troubles (Requesting Advice)-screen-shot-2014-12-19-4.56.50-pm.png
Old Dec 19, 2014 | 09:43 PM
dusty1's Avatar
I would first search for vacuum leaks. Couple of techniques to choose from and a lot of possibilities of leaking.
Also you can test the o2 sensors with an ohm meter. I would recommend replacing both (if not all) anyway, not just the 1. Make sure you have a solid clean connection at plug.
Old Dec 19, 2014 | 09:44 PM
dusty1's Avatar
Found this.......
https://landroverforums.com/forum/di...1-p1174-50352/
Old Dec 20, 2014 | 12:46 PM
I don't know about Rover's in this regard as most of mine until a month ago were not that smart. In most cars though a failing cam sensor will retard the timing etc causing a serious loss of power. My 2 cents.
KO SALES TEAM
Feb 2, 2009 01:00 PM
Sean 1313
Jan 13, 2006 06:25 AM
oberdahill
Sep 10, 2005 11:17 PM
FloppyRunner
Sep 10, 2005 06:32 PM
Dave_Liverpool
Jun 22, 2005 11:29 AM
