dies on me!!!
Old Apr 10, 2009 | 01:36 PM
crainb45's Avatar
Default dies on me!!!
new 95 disco died all the way home on me when i hit the clutch. rpms wld drop to 0 but would start right up again. doesn't die if i keep some pressure on gas. any ideas???!!!
Old Apr 10, 2009 | 02:50 PM
When did you last replace your fuel filter?
Check for vacuum leaks, dirty t/body or idle control unit.
Old Apr 10, 2009 | 02:56 PM
crainb45's Avatar
checking for vac leaks. i really need a manual but cant find one anywhere
Old Apr 10, 2009 | 03:01 PM
crainb45's Avatar
and when i got it home it wont do it on the driveway, just when i pull in the street..guess its a homebody
Old Apr 10, 2009 | 03:50 PM
AK Rover's Avatar
http://green-oval.com/joomla/index.p...d=13&Itemid=29
Click on the link and download the RAVE manual. It will tell you everything you need or want to know about your Disco.
Old Apr 10, 2009 | 06:30 PM
Remove and clean your idle air control valve, also know as the stepper motor.
It is closest to the opening on the throttle body.
When these get really dirty or go bad your truck wont idle.
Old Apr 14, 2009 | 01:11 PM
crainb45's Avatar
only did it that one day, talked to prev owner and he said it would do it every once in a while. any one have similar experience? is this a common problem with discos?
Old Apr 14, 2009 | 05:34 PM
You need to clean the throttle body and the stepper motor (idle air control), that is what controls your idle speed.
If it is to dirty or bad it wont let the truck idle, if you hold your foot on the gas and keep the RPM above 550 she will run all day long.
Do you know the last time it had a tune up?
Are you using premium gas?
Old Apr 14, 2009 | 06:00 PM
crainb45's Avatar
Just bought it so haven't had a tuneup yet. Pretty sure the guy before me ran regular but I'm on my first tank of premium. Ordering a manuel so I'll clean the stepper as soon as I get it in
Old Apr 14, 2009 | 06:13 PM
You dont need the manual to clean the stepper motor, it is on the front of the throttle body, closest to the opening.
Unplug it, remove the two screws and soak it with carb cleaner, also clean the opening it goes into.
DO NOT turn the plunger or move it in any way.
You can take a toothbrush to it, also the opening.
Put it back, plug it back in.
Done.
Also read the "how to clean a t-body" thread on the top of the page.
jlester@mt.gov
Mar 26, 2008 09:30 PM
smartkiduwey
Nov 13, 2007 06:50 AM
rravenn13
Jun 18, 2007 12:49 PM
robdis96
Jun 8, 2007 05:28 PM
sansime
Oct 16, 2006 01:54 AM
