Dies For No Reason
Old Feb 24, 2020 | 11:31 PM
LeatherBoots's Avatar
Default Dies For No Reason
I have a 2000 Land Rover Discovery 2 V8 with 290,000 kilometers (about 180,000 US miles).
Everything is perfect - No codes or leaks. The car just randomly dies. The Engine, the Electrical system, everything goes black. Then it restarts with no problem. It has usually down this when slowing to a stop. Crank Position Sensor was replaced with new Bosch 20,000 miles ago.
Could it be the idle control module? I am not sure what could make it suddenly turn off like a switch. Again no problems restarting. There is a bit of a pulsing to the exhaust that comes and goes.
Old Feb 24, 2020 | 11:43 PM
Forgot to say the pulsing exhaust is at idle..but you have to listen hard for it .. other than this can't see any symptoms other than just shutting off like a light switch.
Old Feb 25, 2020 | 12:39 AM
Any ideas on what would cause a Rover to suddenly die for no reason ?
Old Feb 25, 2020 | 01:38 AM
Come on man .. anyone?
Old Feb 25, 2020 | 02:39 AM
Frank4's Avatar
Bad ground? I had a similar issue a while back. It was the negative cable from battery to frame
Old Feb 25, 2020 | 04:17 AM
Extinct's Avatar
Does it happen hot or cold or both? No codes I assume. Do you have the torque app and an elm327? what do the oxygen sensor graphs look like? What are the MAF sensor readings? How often does it happen - once a day? Once an hour? Once every 3 stops?
My initial guess is MAF related, but could be IAC.
Old Feb 25, 2020 | 05:57 AM
redwhitekat's Avatar
Clean your battery terminals
Old Feb 25, 2020 | 12:11 PM
XRAD's Avatar
do all the dash lights come on when it dies? or does EVERYTHING go dead...
Old Feb 26, 2020 | 05:11 AM
Everything goes dead.
Old Feb 26, 2020 | 05:12 AM
Everything in the car goes dead. No lights. Just dies.
