Which diff fluid weight?
Old Mar 27, 2016 | 12:07 PM
Bom2oo2's Avatar
Originally Posted by mollusc
Why did you have the engine running? RAVE and other manuals all say to change the ATF while the transmission is cold, then run the engine and gently cycle through the gears, then shut off the engine and top up.
You can drain & refill with engine off, but to fill to correct level you have to have engine running go trough all gears then put in park or N (with engine running) & fill it again , or you will be low on ATF at least couple quarts,
Old Mar 27, 2016 | 01:06 PM
jamieb's Avatar
Yes, proper procedure is drain and refill cold, start engine, cycle through gears, and with engine still running crawl under and add fluid until a steady stream pours. Test drive, recheck again or the next day. Engine should be cold before starting the procedure though.
Discovery_Scott
Oct 1, 2014 07:45 AM
JamesDisco97
Mar 4, 2012 01:21 PM
AK Rover
Mar 20, 2009 09:51 PM
duckprefect
Freelander
Mar 9, 2009 08:27 AM
LRScott
Mar 4, 2009 08:39 AM
