Diff Lock stuck/not working Disco 1 1994
Old Apr 2, 2007 | 01:03 PM
johnkbl's Avatar
Default Diff Lock stuck/not working Disco 1 1994
Yesterday I was working in my Disco 1994 3.9L It has several electrical problems, and the transfer solenoid was not releasing the transfer when the gearbox was in N. I found the problem, and after I fixed the wire, the solenoid started working normally, but the lever can be shifted only betwen Low, N, and High. I can not shift the lever to Diff Lock neither in High, low, or N.
Anyone here with a similar experience/problem?
Thanks for your help!.
Old Apr 2, 2007 | 01:08 PM
Default RE: Diff Lock stuck/not working Disco 1 1994
You may find that the linkage is bound up, happens quite often when not shifted much. Might want to go under the truck and clean and lube the linkage.
Mike
cornbreadj
Dec 27, 2014 07:50 PM
ImQuattro
May 1, 2014 08:36 PM
booper169
Nov 3, 2010 08:24 PM
tomfraser
Dec 7, 2008 03:54 PM
