are diff lock and transfer case cables the same?
Old May 13, 2010 | 07:22 PM
03discoman's Avatar
Default are diff lock and transfer case cables the same?
are they the same cable? length?
Old May 14, 2010 | 09:23 AM
03discoman's Avatar
nevermind, i found out that they are different lengths..... damn...where am i gonna find a diff lock cable
Old May 14, 2010 | 09:27 AM
What are you trying to do? If you have installed a CDL diff. or t/case into an 03 then the 04 cable set up will work fine.
Old May 14, 2010 | 03:14 PM
03discoman's Avatar
i got a 04 d2 shifter for free...but the diff lock cable was cut.....in half!!!!
so i called the dealer and they want 240$...just for the cable....
i decided to make my own cable repair from the 2 halves that i have left.....
unless someone knows where i can get a complete diff lock cable assembly without spending more than 50$
Old Feb 10, 2011 | 10:45 PM
wildlifeguy's Avatar
is the diff lock cable the one that locks the diff into 4x4 low range?
I need to replace that cable, but don't know what the bloody thing is referred to or how much it cost to repair. Any suggestions?
Old Feb 11, 2011 | 02:17 AM
Urban Panzer's Avatar
If you have both halfs, weld it back together, then simply clean the welds so it still "smooth" then cover the area with some convulated tubing and heatshrink....
Old Feb 11, 2011 | 08:48 AM
dcarr1971's Avatar
The CDL shifter has 2 connections...at least the D1 shifter I installed in my D2 does. One shifts the transfer case from H-N-L by moving the lever forward or back. The second connection moves the Center Diff Lock nipple from unlock to lock when the lever is moved from one side to the other.
If you don't have the CDL shifter, then the cable you're asking about just shifts the transfer case from H-N-L.
In the event that you can't perform the repair described by Urban Panzer (above), you might want to look into upgrading to a D1 transfer case shifter. It is time consuming, but a lot cheaper than spending $240 for a cable...
Old Feb 11, 2011 | 09:26 AM
Bundu's Avatar
Banned
FYI... the 04 shifter he is asking about has 2 cables, one for H-L and one for CDL.
cornbreadj
Dec 27, 2014 07:50 PM
kunz209
Sep 6, 2014 05:55 PM
safarisam
Jun 9, 2010 05:52 PM
Darover
Sep 18, 2009 05:22 PM
Loose_Screws
Jul 22, 2005 12:13 AM
