Diff/TC oil change
Old 08-24-2013, 08:34 AM
MeanSaleen's Avatar
Default Diff/TC oil change
Hey all. Question will i be able to change the front/rear diff and transfer case oil with the truck on the ground? How much of a pita will it be? Thanks :
Old 08-24-2013, 08:36 AM
dusty1's Avatar
I did mine on the ground, no problem. a transfer pump is highly recommended.
a 2" lift helped also, but not a must. http://www.tooltopia.com/mityvac-mv7...Fevm7AodKV4AoQ
Old 08-24-2013, 09:04 AM
MeanSaleen's Avatar
a 2" lift helped also, but not a must. Save on Mityvac - MV7241 at ToolTopia.com
I actually have that transfer pump. lol. Did your fill plugs come out easy on the diffs?
Old 08-24-2013, 09:08 AM
Mine did, be sure that the fill plugs come out first, before draining...
I bought ramps, and with both on one side it makes it easy for tubby to get under there.
Old 08-24-2013, 09:15 AM
dusty1's Avatar
^ x2 on the fill plug first. I had no problems with removal of any plugs, but did purchase a couple of those "mud plugs" to replace the originals.
Old 08-24-2013, 10:07 AM
Mojigglins's Avatar
You will need a wobble extension for the fill plug on the t-case. I have the same pump it did not like the heavy 140 weight gear oil, it kinda exploded on me but lasted for the job, I also used 4 4x6 wood beams as ramps and raised the truck 4". Took me about 1.5 he's to do the case and diffs. If its a hot day sit the bottles in the sun for about an hour before you start, thins it out just enough to make it easy to pump.
Happy wrenching!!
Old 08-24-2013, 10:10 AM
And a total of 7 quarts of 85/140 be it synthetic or regular oil.
Old 08-24-2013, 10:25 AM
Chrisinhouston's Avatar
Have fun, there nothing that smells quite like gear oil!
Old 08-25-2013, 07:42 AM
MeanSaleen's Avatar
hahaha. Thank you all for your advice
Old 08-25-2013, 08:22 AM
What about your tranny while you are under there?
Quick Reply: Diff/TC oil change
