Difference Between front drive shafts?
Old Jul 3, 2009 | 05:46 PM
Disco TN's Avatar
Unhappy Difference Between front drive shafts?
Ok here is what I got. I have a 2003 DII I wanted to replace the driveshaft to get one with all grease fittings in the joints etc.
I purchased one from the board here private sale they told me they had bought it for they 2003 DII but only had it in for a short time, forget the reason.
The part number is TVB000110 that shows to be a front shaft for a 99-02 per British Atlantic. I should have a TVB00320 for a 03.
It fit I didn't check the numbers till after I had it installed (It looked just like mine except it had a fitting on the drive sleeve).
So what should I do, Mike I hope you'll see this one and let me know what you think?
Thanks
Doug
Old Jul 3, 2009 | 07:07 PM
There is something like 1/4 to 1/2 in shorter on the 03, don't worry you'll be fine.
Did you lube all your grease fittings?
Old Jul 3, 2009 | 07:18 PM
Disco TN's Avatar
Smile Thank you Mike
Glad to hear that I was worried Thanks for the good news!!
Doug
LeakyDisco
Sep 19, 2010 03:02 PM
marlymarl
Mar 29, 2010 10:54 AM
pennystockart
Nov 24, 2007 03:52 PM
Roverboy3766
Nov 10, 2007 03:22 AM
F451_Guy
Dec 11, 2006 07:54 PM
