Different buildup between left and right heads (pics)
Old Apr 7, 2011 | 10:00 PM
rcrosby's Avatar
Default Different buildup between left and right heads (pics)
I am 1/2 way done with the head gasket job on my 04 disco II. It was what everyone was guessing on here, a coolant leak on the rear left side cylinder causing a miss and white smoke at start up.
Anyone have any ideas on the different buildup between the left and right heads? Left is solid black and right has a lot of white. Anything else I should look for?
Right Head
Both Heads
Old Apr 7, 2011 | 10:15 PM
DarylJ's Avatar
How about a picture of the gaskets from each side?
Left side looks normal-ish. Right side looks like hell, obviously. If both sides were running pig rich like that, the only reason the left would look normal is if you were steam cleaning all 4 cylinders, which is why I'm wondering what the gasket looks like.
Old Apr 7, 2011 | 11:00 PM
rcrosby's Avatar
Left side gasket
Right side gasket
Old Apr 8, 2011 | 08:29 AM
Snafu / Disco Fries's Avatar
So the dirtier side was the one with the leak? Interesting pics and thanks for the sharing. If that is the case, I would figure maybe you were gunking up the plugs or it just was not burning as good as it should with the coolant in the mix. What do the plugs for each side look like?
Old Apr 8, 2011 | 12:34 PM
Wolf's Avatar
Looks like improper firing in those cylinders, could be caused by wet or bad plugs, air fuel mix. Get heads machined and put back together. Use only a premium platinum plug and good luck, keep us posted.
thehun
Mar 7, 2013 01:35 AM
0304Disco
Oct 10, 2011 09:58 AM
ruffram
Sep 1, 2011 08:15 PM
davedeblitz
Dec 6, 2009 03:11 PM
SlcPunk74
Sep 6, 2009 10:38 AM
