Water on drivers side floor
Old Apr 8, 2011 | 10:44 AM
0304Disco's Avatar
Default Water on drivers side floor
Was doing some spring cleaning ie. vacuuming and noticed the drivers side carpet and pad wet.
Any ideas on what the source of this water could be?
Old Apr 8, 2011 | 11:03 AM
ljdiscovery's Avatar
Did it smell like coolant? Could be a leaking heater core, could be a plugged a/c drain, could be a leaking windshield. If it is the heater core, you will probably, but not necessarily, smell coolant. If it is a plugged a/c drain, get under the truck, on either side of the transmission housing, protruding from the bottome of the chassy floor, there are two drain stubs, they are black, about 3 or 4 inches long and are pinched at the bottom. Do a search on this forum and you will find threads with pictures. Try cleaning those out. Be careful, if they are plugged, you may get a face full of rotten fluid coming out when you open them up. We had a windshield replaced recently and during heavy rains found that they passenger side floor is getting wet. It is coming down from behind the glove box. We also have a wind noise that we didn't have before. Someone else may have some other suggestions, but those are easy places to start. Good luck. Phil
Old Apr 8, 2011 | 11:14 AM
0304Disco's Avatar
Thanks!! Now that you mention it,we had the windshield replaced and I bet this is the issue. I need to do some checking.
Old Apr 8, 2011 | 11:16 AM
gavone1976's Avatar
I have that same wind noise on passenger side ,windshield was recently replaced.That noise is really annoying.
Old Apr 8, 2011 | 12:22 PM
Wolf's Avatar
Had my windshield replaced and started getting water into cabin. Found that when they pulled the windshield it separated the metal at the top of the windshield enough to let water come in. Also check the rain rails at top corners of windshield, they crack just like the Fords did. This is another place where water can enter.
Old Apr 8, 2011 | 12:55 PM
Bundu's Avatar
Banned
Just a comment: coolant leak from the heater core would only be on the passenger side.
Wet driver's floor could be a windshield leak, sunroof leak, blocked a/c drains or the driver pee'd himself.
If you have wind noise check that the windshield plenum (the large plastic trim in front of the windshield) is fitted properly and flush with the windshield - ask me how I know. Also check that the trim pieces on the sides of the windshield are properly installed and flush.
MPDano
Feb 6, 2023 04:45 PM
me 2
May 8, 2013 11:47 AM
LRgirlfromMS
Mar 6, 2013 03:51 PM
dougn
Dec 4, 2012 06:25 PM
Princess
Sep 15, 2009 08:02 PM
