Different Cruise controll issue
Old Aug 28, 2006 | 04:12 PM
Prepilot_3ck's Avatar
Default Different Cruise controll issue
I've got an '03 Disco 42K on it. The criuse controll is very "jerky". It's always excellerating or letting off. It's almost nauseating . I've taken it do the dealer for service and, they've replaced "The Computer" and "Reprogramed" the cruise control. It's still doing it. Is this a normal thing?
Brian
Old Aug 28, 2006 | 05:48 PM
Default RE: Different Cruise controll issue
Since you are in warranty, get it into the dealer and let them play with it, hey, do your 45K while you're in there, hell it's free.
mike
Old Aug 28, 2006 | 08:08 PM
Yeah, I really should. Good plan.
Old Jan 22, 2007 | 09:42 AM
03disco's Avatar
6th Gear
I had an 04, new from the dealer, and it did the same. I took it back to have checked out and it still did the same. I now have an 03 and it too is doing the same. Any Help.
Thanks
Old Jan 22, 2007 | 03:05 PM
johnnybob06's Avatar
I've heard on other posts and fourms that you should take your truck to the dealership and have them switch out the cruise control module from a 4.6 to a 4.0??? I believe thats what I heard... correct me if im wrong..
John-Robert
Old Jan 22, 2007 | 03:33 PM
Check the basics, the vaccum lines are the biggest cause of the cruise not working, especialy the long line that goes to the switch on the brake pedal assembly.
Mike
Old Jul 1, 2007 | 03:55 PM
philnewell's Avatar
I have the exact opposite problem on a 2000 Disco II (125K). The dealer replaced the vacuum hoses, but it still did not work, they said I needed a new ECU. While waiting for a new ECU to arrive, I tried the Cruise Control and it worked (kind of) It is very slow to pick up speed, but will eventually get to the set speed. An example of slow is: If I am doing 60 mph on a flat road and the CC is set to 70mph, and I "resume" and let gp of the throttle, the car will slow to 50 mph before the CC starts to accelerate it, it will take 40-50 secs before it gets up to 70 mph.
I thought originally that it was the vacuum hoses still leaking, but I have checked the ones on the vavcuum pump and control switch and all is okay.
I have read the various messages in the forums here that refer to a vacuum hose from the brake pedal to the CC vacuum control switch. However, the service manual does not mention it, and I cannot find it.
Did they change the design between years?
Before I replace the ecu ($300) does anyone have any other ideas.
Regards Phil
Old Jul 2, 2007 | 06:30 AM
03springer's Avatar
Just my two cents, I have a 2001 disco that the cruise control is jerky also. Just a crappy design?
Bob
Old Jul 2, 2007 | 07:02 AM
99XJ's Avatar
I have the same problem on my '03 SE7, I read somewhere else in the forum that's its a simple dealer reprogram. They apparently didn't update the cruise control software when swtinching from the 4.0 to the 4.6L. I think someone said it's about $100 at the dealer. I planb to get mine done next time I head in.
Old Jul 2, 2007 | 11:41 AM
Aquaholic's Avatar
I had the same problem on my '03 and the dealer just reprogramed - works great now.
Greenhead
Jan 25, 2014 04:09 PM
TTtheBear
Apr 10, 2013 01:19 PM
ajmille
Mar 30, 2011 07:17 PM
Core_Shot
Jan 28, 2008 07:55 PM
sierrafery
Jun 30, 2007 04:35 AM
