cruise controll and horn
Old Mar 30, 2011 | 07:17 PM
ajmille's Avatar
Default cruise controll and horn
2001 disco II SD
Hello, well I found out my c c dosnt work, I pressed the botton just off to the right of the dash, then hit set while I was at the speed and it didnt hold, th cc button does lite up.So I looked under the hood found the vacume hose broken, (replaced it), still no luck, now on the bottom of the cc there is a male connection that dosnt have a hose at the end, cant see where it could go to.I dont under stand as all the other cars I had, a vacume line was conected to the manifold, the land rover does not have this.So I read up some more, found if the fuse to my horn was blown that would effect the cc, so I looked as my horn didnt work.Well this time the fuse was blown, I replaced it, it worked once then stoped working, but it didnt blow the fuse.O' yea, I read another post hear and there is no vacume line that goes from the cc through the fire wall by the brake master cylender.
Thank you for looking
texmbr
Dec 4, 2010 08:53 AM
lipadj46
Aug 13, 2009 07:47 PM
southfloridadiscoII
Jun 28, 2009 11:03 PM
Prepilot_3ck
Jul 2, 2007 11:41 AM
sierrafery
Jun 30, 2007 04:35 AM
