Differential Leak?
Old Apr 23, 2010 | 08:48 PM
Spencerfitch's Avatar
Default Differential Leak?
Im checking out a land rover a good distance away. The owner was nice enough to get me pictures of everything including underside of truck and I see the rear differential has what seems like a leak out of where the drive shaft attaches. Is this common? Is there a seal that is replacable in this area?
Old Apr 23, 2010 | 08:57 PM
Long Haul's Avatar
Its probably just the pinion seal leaking. Nothing to far out the ordinary just probably needs a new seal.
Old Apr 23, 2010 | 09:01 PM
I just found a writeup on it thanks, seems easy enough
Old Apr 24, 2010 | 09:12 AM
Plan on doing a full major service on whatever you buy as well as replacing/rebuilding the front drive shaft and plug wire replacement with either 8 mm STI or Magnacor wires.
Old Apr 24, 2010 | 09:22 AM
XCELLER8's Avatar
the diffs and t-case have vents on them.....if the vent is plugged , as the diff warms up pressure will build up inside and push the oil out the seal.....very common on these.
Old Apr 25, 2010 | 02:43 PM
Danny Lee 97 Disco's Avatar
Where are the vents? Is there a way to clean them?
Old Apr 25, 2010 | 02:51 PM
It's usually called a breather. It's also normally ontop
of the differential a little capped of nupple. Remove it wash it. If you blow through it it's good.
Old Apr 25, 2010 | 08:39 PM
oysterhead's Avatar
My breather is a long rubber tube attached to the top of the diff.
Old Apr 25, 2010 | 09:48 PM
tweakrover's Avatar
where was this write up?
arijfeli
Dec 30, 2008 05:34 AM
rgrizzard
Mar 6, 2008 10:16 AM
ElMaestro
Aug 3, 2006 11:38 PM
toxico
Oct 20, 2005 02:15 PM
03se3
Freelander
May 24, 2005 12:36 PM
