Differential lock plug,spring & ball
Old Mar 17, 2016 | 12:02 PM
Micko's Avatar
Default Differential lock plug,spring & ball
02 discovery without cdl.
Picked up an 04 transfer case last year and just got around to resealing it and hopefully next week swapping it in.
I assumed to the right of the Differential lock warning lamp switch there would be the differential lock plug, spring & ball.
As U can see in the pic there is another Differential lock warning lamp switch there.
My question is did someone swap it out?
Thanks
Micko
Old Mar 17, 2016 | 01:18 PM
abran's Avatar
The last 04' case I resealed had 2 electrical plugs screwed in there.
Old Mar 17, 2016 | 02:29 PM
acg's Avatar
acg
I would love to hear what you found out. I have a similar situation with a 2004 T/case transplanted into my 2003 Disco.
Old Mar 17, 2016 | 02:40 PM
number9's Avatar
They have two warning lamp switches, one may be for the audible chime on '04? It's a different indication/warning system than the previous years. Red versus amber lights supposedly. Rave doesn't seem to show second switch in the WDM.
Old Mar 17, 2016 | 03:50 PM
DiscoCam's Avatar
I believe that one switch is for the diff lock and the other is for the transfer box neutral warning. Both lights are amber on my 04.
Old Mar 17, 2016 | 04:12 PM
number9's Avatar
Neutral warning switch is on box main case per manual the same as prior years.
Old Mar 19, 2016 | 08:04 AM
Micko's Avatar
So when I go to hook it up to my 02, Ill connect the one on the left (Differential lock warning lamp switch) & disregard the other.
I assume there will be a connection for the differential lock warning lamp switch on the 02
Thanks again guys
Micko
archaeology_student
Feb 11, 2015 09:49 PM
jalodge
Apr 15, 2014 02:16 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
southfloridadiscoII
Jun 18, 2009 08:48 AM
