Differential question
Old Apr 15, 2009 | 09:06 PM
AK Rover's Avatar
Default Differential question
I should probably know the answer to this but I'll ask anyway. Are the axle third members the same on D1s and D2s? I know about the different flange for the rear with rotoflex but that's not a problem since mine has a u-joint there. I'm thinking of finding cheap third members and having them set up with gears and lockers as I can afford to. So far I have found third members on ebay ranging from $100 - $250 depending on what year they came from and the mileage. I figure that the housing itself doesn't wear, just the internal parts. I want to go to 4.11 gears in the axles with more than likely Trutracs front and rear.
Old Apr 16, 2009 | 07:31 AM
roverguy7's Avatar
same across the board... even p38s are the same, aside from rears on p38s are 4 pin, all disco are 2 pin. but front and rear will swap fine, and yes, youll have to change the flange
Old Apr 16, 2009 | 08:31 AM
AK, call me.
Old Apr 16, 2009 | 08:37 PM
AK Rover's Avatar
I'll give you a call tomorrow Mike. Been busy accomplishing nothing today.
mrossipir
Jan 1, 2009 10:54 AM
workingclass
Sep 19, 2008 06:34 PM
workingclass
Sep 19, 2008 03:14 PM
TJC952
Feb 10, 2008 08:40 PM
ElMaestro
Aug 3, 2006 11:38 PM
