DII 04 SE7 "Engine Noise"
Old Apr 8, 2010 | 08:24 AM
vandev's Avatar
Default thanks mike
Originally Posted by Disco Mike
Any one with an internal engine noise needs to first do a oil pressure tested as posted earlier, that is a must before doing anything else.
If the pressure is good, then have the rocker shaft, arms, push rods and lifters inspected for wear. Any one of these will cause the problems and they are not a major issue.
Thanks Mike i will do check tomorrow and post findings. So if i am correct, test cold and then hot?
Thanks again Mike, Chris
Old Apr 8, 2010 | 09:07 AM
Yes. Take it to the shop and leave it over night, have them then cold start it testing at idle and at 2000 RPM's, then when at operating temp.at idle and 2000 RPM's.
Old Apr 8, 2010 | 04:05 PM
vandev's Avatar
Default hey spike
Originally Posted by Spike555
Has anyone thought about the knock sensors?
What grade and brand of gas are you using?
I had a Oldsmobile that I bought brand new with the 3.1 and it "knocked" like that from day one when hot and still did it when I sold it 120,000 miles later.
Is there anyway to test the knock sensor/ i remember now when i was doing my engine mounts what this open wire was dangeling to the bottom of the engibe block. i am wondering now. I am doing a pressure test tomorow if i have time if not saturday for sure.
Let me know, thanks Chris
Old Apr 8, 2010 | 08:07 PM
Electrician I am not therefore I have no idea if or how to test a sensor including the knock sensors.
But to me it makes sense that if it only knocks under load that it could possibly be spark knock from low grade fuel or bad knock sensors.
Old Apr 8, 2010 | 08:25 PM
vandev's Avatar
Default makes sense
It makes sense to me...maybe i unplug it and see anything changes...if not should be a knock sensor as i am using high grade super... I would say it should be that simple but i have a land rover and nothing is just that simple...
Thanks Chris
Old Apr 8, 2010 | 11:14 PM
greg409's Avatar
It's a shame you didn't mention that earlier,
Id still be concerned having not heard it, but a pre-ignition does resemble a wrist pin sound.
More like a dozen marbles rolling around in a thick wooden box, a rod knock is more rythmatic with engine rpm.
You can't rule out the knock sensor, although while it will retard the spark, I don't know if a bad (disconnected) one can advance the spark causing pre-ignition.
Worth looking into.
luck,greg
jycsalas
May 23, 2019 03:02 PM
david4ducati
Mar 1, 2015 07:59 PM
jmason
Mar 12, 2013 08:08 PM
kpl1228
Feb 5, 2012 02:47 PM
WaltNYC
Jun 9, 2011 10:08 AM
