DII Air to coil issue, any ideas?
Old Nov 6, 2010 | 12:08 PM
Livingstone's Avatar
7th Gear
Default DII Air to coil issue, any ideas?
I have a question for anyone who has replaced their SLS with coils. I just installed Terrafirma HD all around on a '99 DII and there is a clicking sound every 10-15 seconds emanating from the compressor. I've pulled relay 5 but my new battery is dead in the morning from this attempted power draw. (battery voltage going from 12.42 to 12.37 as it clicks) Anyone else experience this? Are there any other components or fuses to pull. The LR dealer is 3 hours away, Is that my only option to have them reset the ECU to coil?
Thanks For any Info
Old Nov 6, 2010 | 12:25 PM
NiteTrain's Avatar
i pulled out my compressor
Old Nov 6, 2010 | 12:32 PM
7th Gear
I tried pulling the plugs for the compressor and also the height sensors which gave me the constant audible warning chime.
Old Nov 6, 2010 | 01:20 PM
Pull the 2 fuses, 1 in the engine compartment the other in the inside fuse block.
Old Nov 6, 2010 | 01:25 PM
7th Gear
That's the 30A in the engine compartment, truck w/ arrows up/down icon I assume, but what's the one on the interior labeled as?
Old Nov 6, 2010 | 01:26 PM
Check your owners manual.
Old Nov 6, 2010 | 01:31 PM
7th Gear
Fuse 28 is SLS but also ABS, Won't that be a problem?
Thanks for the help, Much appreciated.
Old Nov 6, 2010 | 01:34 PM
Try with just the 30 amp fuse. If that doesn't work you will need to have some shop, with the proper scanner shut the SLS down.
Old Nov 6, 2010 | 01:38 PM
7th Gear
I'll give that a try. Strange that this usually isn't a problem, Rovers North hasn't heard of it either. Wonder why my truck is so "special"
tigertrakstar1
Mar 5, 2014 04:13 PM
augustwillo
May 13, 2013 07:10 AM
Evan5291
May 9, 2012 02:08 PM
martin1804
Jan 21, 2012 01:42 PM
b_woodroaster
Nov 5, 2010 08:54 AM
