Air - Coil - Air Pump
Old May 12, 2013 | 07:03 PM
augustwillo's Avatar
Default Air - Coil - Air Pump
So I am looking to exchange out my air bags for coils. Got my coils in and seeing that it's not all that easy to do this procedure. I had a thought about keeping my compressor and converting it to a air pump... to pump tires and all. An onboard system. Anything thoughts or pictures of someone doing this?
Old May 12, 2013 | 08:09 PM
It won't work, the pump will not handle the necessary voluum or pressure.
Old May 12, 2013 | 08:43 PM
What about for small tubes, like ones in bikes?
Old May 13, 2013 | 06:55 AM
drowssap's Avatar
it would probably work for something like bike tire, but why you can buy one for that for 9.99 at HF. I'm sure you could sell you stock compressor on ebay for more than that. tell you what take all that sls stuff that you don't need and more box it up and send it to me and I
I'LL send you a compressor for you bike tires
Old May 13, 2013 | 07:10 AM
Also - when you remove the air bags, the computer still thinks they need to be "plumped up" during the time the vehicle is off. Disconnect the compressor, and you still have a power drain from time to time, enough to kill a battery. Turns out to be the electric valves, and an easy way to disable them is remove the common ground that appears under the hood on the same bolt stud with the fuel pump ground.
trialrun
Nov 11, 2014 08:41 AM
Sandman0306
Dec 15, 2012 03:24 PM
b_woodroaster
Nov 5, 2010 08:54 AM
ajh
Jan 11, 2008 11:19 AM
hector5016
Nov 23, 2005 09:21 PM
