DII Rock Slider Plans FOUND
on
I have used a es up like those for 7 plus years, never had a problem or failure of any kind and they can be built for normal wheeling or sever wheeling based on the metal used. I ran 3/16 ths. plate and 2X4 box steel for more H.D protection.
There is no need or benefit to bracing all the way over to the frame.
Nice design, it doesn't seem to show the cut required to make the bend to form fit the sill. That location and size would be important, I guess. I would like to see the press or tool used to then do the bend after the cut is made..That seems to be the challenge to the at home slider project.
I like the smooth edges, that is some nice welding and finishing work.
