DII Transfer Case FIll plug Size?
Old Oct 22, 2012 | 07:27 AM
Grumpo's Avatar
Default DII Transfer Case FIll plug Size?
I couldn't find a thread on what size the D2 fill plug was. I need to purchase a wrench to undue the drain plug but was hoping you guys may already know the exact size to get.
Thanks
Old Oct 22, 2012 | 07:32 AM
drowssap's Avatar
it is a 1/2 drive, use a 1/2 drive extention just insert the extention into the plug. I found a 1/2 drive extention with a 1/2 drive universal on the end works nicely it lets to reach up over the top of the crossmember.
Old Oct 22, 2012 | 09:06 AM
Grumpo's Avatar
Hmm. That's what I had read but a 1/2 inch drive won't fit into the end of the bolt. PO must have replaced the fill plug with a solid bolt.
Old Oct 22, 2012 | 09:14 AM
drowssap's Avatar
that is possible I think D1 had bolts
Old Oct 22, 2012 | 12:00 PM
jfall's Avatar
Best way to put the 90 weight oil in?
I need to do this soon too..
My transfer case is a leaker.
Old Oct 22, 2012 | 12:22 PM
drowssap's Avatar
buy a $20 garden pump sprayer at Homedepot fill it with 90wt pump it up and crawl under the truck you can reach right over the top of the crossmember right into the fill hole.
Just take the spray nossle off the end, works great no 90 wt runnung down your arm and you dont have to hurcules to sweezing the bottles.
Jared9220
Apr 11, 2014 10:52 PM
Disconoobie
Oct 19, 2010 07:36 AM
Disco Alan
Apr 21, 2009 06:22 PM
jrkstore43
Mar 2, 2009 08:27 AM
Phototone
Apr 7, 2008 03:59 PM
