Disable engine for compression test
Old Jun 4, 2014 | 10:51 AM
ejag42@mac.com's Avatar
Default Disable engine for compression test
What is the easiest way to disable the engine for a compression test?
Thanks,
Rod
Old Jun 4, 2014 | 10:59 AM
jfall's Avatar
Usually one takes out all the spark plugs.
This is done to gain cranking speed and make the test fair and accurate.
Then you put in new spark plugs.
Otherwise, pull the fuel pump fuse.
Old Jun 4, 2014 | 11:46 AM
Ah, fuel pump fuse, of course. Thanks. It was much simpler when all one had to do was pull the HT lead from the coil. Now I can't even see the coil (s).
Rod
I wouldn't think cranking speed would make much difference (within reason).
Old Jun 4, 2014 | 02:11 PM
dr. mordo's Avatar
Also, fuel pump relay in under the hood next to the windshield washer relay.
I'd pull it, crank it over a few times to be sure there's no fuel in the system, then do the test.
bcolins
Jul 13, 2013 08:43 AM
bradman951
Apr 22, 2013 01:07 PM
msm15
Jan 18, 2011 09:54 PM
btbaus
Jan 20, 2010 04:38 PM
afphinfan
Jan 1, 2008 05:58 PM
