Disabling ace
Old Jan 23, 2024 | 06:19 PM
HammyMc's Avatar
4th Gear
Default Disabling ace
My ace valve block is leaking, if I pull the fuse or relay will it still leak. If it ran dry would this still put the vehicle at risk of fire.Im aware the dash light will come on. I'm waiting till I have time to attempt a seal renewal but I'll still need the motor in the mean time.
Any advice(relevent) will be appreciated If its not relevent at least make it funny!🤣
Old Jan 24, 2024 | 07:59 AM
mollusc's Avatar
You could pull the fuse/relay and install a non-ACE serpentine belt so the pump is no longer being driven.
Old Jan 24, 2024 | 08:39 AM
H Hill's Avatar
Mine was leaking and it was determined (by an excellent LR independent shop) that the aluminum valve block and the steel lines corroded badly with the aluminum too badly pitted for the seals to work. I found a company in the UK that sold rebuilt/remanufactured ACE blocks. https://www.designdevelopmenteng.co....ded-p389433934
I installed it and mine works great!! It has all new parts, valves, electrics and fittings. Just carefully measure and cut your existing steel lines, mount and install the new one.
Works great!
Old Jan 24, 2024 | 12:16 PM
HammyMc's Avatar
4th Gear
Well I'm hoping the new seals will do the job, the pipes are in pretty good nick as is the valve block. Even if I can get more time out of it to save up to do what you've done I'll be happy.
Old Jan 27, 2024 | 12:53 PM
St1ck's Avatar
Works great!
That’s a good find. Thanks for the link.
The wanderer
Aug 18, 2022 07:04 AM
ericjlamyot
May 6, 2020 05:25 PM
difrentbob
Apr 12, 2016 04:04 PM
H Hill
Apr 11, 2015 09:40 PM
earlyrover
Apr 30, 2013 03:33 PM
