Disabling Rear SLS
Old 07-11-2018, 06:33 PM
DiscoCam's Avatar
Default Disabling Rear SLS
Hello everyone. I finally have time to work on the D2 again so I am tackling something I have wanted in a 4WD for a long time. I am installing an air compressor and tank from Viair. My D2 has a 2" lift and had rear SLS so no more air bags. However, everything else is still there (height sensors, air lines, air compressor). I want to put in my new air compressor where the SLS one lives right now, but I removed it and now there is an air suspension fault (obviously). I could live with the light on the dash, but it constantly beeps when you go over 20mph.
Any way that I can disable this? Maybe clip specific wires for SLS going to the SLABS or do I have to get it reprogrammed? Could I replace the SLABS with one from a non SLS truck and have it work? Would be a good excuse to get an 04 SLABS as I have added a CDL.
If none of those would work, I do have to get it reprogrammed right?
Thanks in advance.
Edit: I also think that the air compressor might be killing my batteries. Truck had a year old battery when I bought it and PO said it was on its way out. I replaced it because it died a week later and now that battery died two weeks ago.
Old 07-11-2018, 07:08 PM
mollusc's Avatar
The SLABS needs to be reprogrammed when you switch to coils. That will get rid of the errors and then you can just unplug/remove everything.
Old 07-11-2018, 07:20 PM
Received 1,481 Likes on 1,209 Posts
what he said
Old 07-12-2018, 03:26 AM
what he said
X1 .............. yep.
Old 07-12-2018, 12:24 PM
DiscoCam's Avatar
Looks like a pretty definitive answer. Alright then, I'll take it to my indy mechanic for reprogramming. Thanks everyone
Old 07-12-2018, 04:03 PM
Best4x4's Avatar
Received 2,249 Likes on 1,667 Posts
Reprograming or another SLABS with SLS disabled. Then remove the SLS relay.
Big Jim Swade
03-11-2016 05:08 PM
rug man
12-10-2015 10:43 AM
outdoor7or24
05-20-2012 06:44 PM
DiscoIIBrandon
12-02-2010 02:42 PM
grcurry
07-27-2009 04:44 PM
Quick Reply: Disabling Rear SLS
