Disabling the three amigos
Old Dec 11, 2008 | 05:05 PM
Disco2Guy's Avatar
Default RE: Disabling the three amigos
Stick with the OEM pads. They don't produce much brake dust, but can still squeal and set off the 3 amigos. My front left is doing that right now.
Old Dec 12, 2008 | 10:58 AM
ORIGINAL: grussell
I can do the brakes. I have performed my own maintenance on all my other vehicles, but I am a new Rover owner so look to the forum for advice on particulars. I installed the Magnecores and Bosch plugs from recommendations from you guys and the results were good. What brand pads do you recommend? Any particulars about Rover brakes.
Garry
01 Disco SD 106K
Keller, TX
Go to Atlantic British, they offer a good selection to pick from based on your driving habits. At your mileage you may be needing rotors. Make sure to use lots of sound deadening material and do a full brake bleed, 3 pints of DOT4.
Old Dec 12, 2008 | 11:00 AM
ORIGINAL: Disco2Guy
Last I heard, Rover OEM pads can be made by any of 3 different companies, all using the same box, and they are not all equal in their performance, dust and squeaks.
Old Dec 12, 2008 | 12:13 PM
grussell's Avatar
Yep, pulled one of the wheels off this morning and its time for pads and rotors. What do you know the rotor locator screw is stripped out too. Thanks for the info...
Robover01
Nov 3, 2021 06:31 PM
Eddie Parr
Jul 27, 2011 02:01 PM
shaka khan
May 31, 2010 12:08 PM
CopperMtnGuy
Mar 17, 2010 06:22 AM
alemurill
Jul 21, 2008 11:02 AM
