Disc II transmission maint. PO741 ?
Old Aug 2, 2010 | 10:08 AM
AngelaS's Avatar
Default Disc II transmission maint. PO741 ?
Hello,
My husband changed the transmission filter on our 1999 Discovery II, and after a bit of trial and error got the fluid level back up to where it needed to be. It seems to work fine, but the service engine light appeared. He hooked it to a computer and the code reads PO741. Is there something he still needs to do? I want to drive it, as it appears to be working fine, but don't want to cause an unknown problem... thanks in advance for ideas!
Old Aug 2, 2010 | 11:09 AM
lipadj46's Avatar
How much ATF did he end up adding back after draining? Assuming he did a drain and refill. You usually get about 5 quarts out and 5 back in but you have to be in gear while adding to get that much back in. King of scary to be under the truck with it in gear even with the e brake on and someone holding the brake. you can also just run through the gears and go back and top off, do that a few times and get really close.
Old Aug 2, 2010 | 11:11 AM
Bundu's Avatar
Banned
Look under "Write ups" and "How To"
Old Aug 2, 2010 | 07:42 PM
AngelaS's Avatar
Thank you for your reply. He did get 5 quarts in, but didn't do it in gear (in park). He put the fluid in the port above the transmission pan at the base of the bell housing with the vehicle first on a hoist, and again jacked up. Cleared the code and it has not come back, but it still seemed to shift slow in lower gears.
euronavdiscs
Feb 6, 2016 03:41 PM
DangBritish!
Mar 6, 2013 07:38 PM
blueovaltech
Jun 3, 2008 09:07 PM
rcendo
Dec 22, 2007 08:19 PM
pxm045000
Nov 3, 2007 12:55 PM
